ErwinvanGulik
Sep 07, 2020Follower
Optimal connectivity
Dear reader, I bougth the ORBI RBR 50 system with Two satellites. Router is at base Floor, first satelitte is at first Floor (wired), second satelitte at the second Floor (wireless). I ha...
- Sep 07, 2020
ErwinvanGulik wrote:Dear reader,
I have Two questions:
1. Can I manually select the Access point to connect to? If so, how?
2. In case an Access point fails connection, does the system automatically reconnect to another Access point which is available at that moment?
No, the Orbi that has the strongest signal to the device, is the one the device will connect to.
If one satellite fails, and the other satellite is close enough for a connection, the device will connect to that satellite.
michaelkenward
Sep 08, 2020Guru - Experienced User
ErwinvanGulik wrote:1. Can I manually select the Access point to connect to? If so, how?
If you can explain why you want to do this, perhaps someone can offer a suggestion.
