jjodod1
May 28, 2021Aspirant
Optimize Orbi Mesh System
[ Spoiler ]
jjodod1
There is no other modem. The Orbi is directly connected (Ethernet) to Fios. Verizon does rent and sell a modem, but both Verizon and Netgear support say the RBR40 can also be used as a modem.
CrimpOn
May 28, 2021Guru - Experienced User
jjodod1 wrote:There is no other modem. The Orbi is directly connected (Ethernet) to Fios. Verizon does rent and sell a modem, but both Verizon and Netgear support say the RBR40 can also be used as a modem.
If someone at Netgear Support says the RBR40 is a modem, there is no polite say to say, they are full of s**t.
Notice on page 1 of the RBR40 Product Data Sheet, "comes with Orbi WiFi router and satellite". (no mention of "modem.") On page 4, "What do I need for Orbi to work? Connect to existing modem or gateway."
https://www.netgear.com/images/datasheet/orbi/RBK40.pdf
The FIOS box is a combination modem/router/WiFi device.
I mentioned the terminology issue because (a) referring to devices incorrectly can confuse people trying to answer the question, and (b) to point out the potential problems of having two routers.
None of this has anything to do with the central issues:
- What is the optimal way to arrange three Orbi units in a 4,000 sq. ft. building with three occupied floors?
- Will this Orbi configuration be sufficient, or would it be worth investing in a more expensive system?
Sorry for the rant. It's late.
