drafferty
Aug 16, 2022Aspirant
Options for network/mesh upgrade
Hello I have an older network/mesh system AC3000 with RBK50(1 router and 2 satellites) plus RBS50Y. What would be a good noticeable upgrade and are upgrades to new systems easy? Do newer systems dow...
Aug 16, 2022Guru - Experienced User
I'm a fan of the RBK50 series. They work great. I didn't notice much difference going from my 50 series to the RBK750 series. I did going to the rbke963 series but that's a huge cost difference. And a lot depends on what your device is. Its not usually the router that is the bottleneck in speeds but your phone/tablet/computer.
What are you looking at upgrading to?
Or are you just needing more speed?
What are you using it for to need more speed?
drafferty
overall , more coverage and at times tv streaming spins. I adding another rbs50 to other side of house along with the rbs50y out on patio.
use for streaming tv and some gaming.
