kmikol42
Mar 16, 2021Tutor
Orb RB40 MAJOR DNS Issue
My $300 dollar Orbi investemnt appears to be a waste of money after 4 months use. All of a sudden the Router stops responding to DNS requests. I work in the network engineering field and have over ...
kickworm
Mar 17, 2021Guide
I'm so glad I checked the forums! I just today started having the same issue as you. I'll be using the internet as I normally do and then my network icon will suddenly show that I'm not connected to the internet. I recently upgraded to a faster internet plan so I thought that was the cause. It was weird, though, because the modem was online (status lights all good) and the Orbi (RBK50 running latest firmware) was not giving me the purple ring indicating that something was wrong with the modem.
During my troubleshooting, I noticed the DNS error message thrown by my web browser. I got curious and manually set my computer's DNS to Google's (my Orbi is set to use OpenDNS). Low and behold, my network icon still showed that I was not connected to the internet, but I was able to surf the web. Thinking that something was wrong with OpenDNS, I logged into my Orbi and set the DNS to automatic. Problem solved.
That was about 5 hours ago. Fast forward to a few minutes ago and the same issue happened. Network icon on my computer indicated that I was not connected to the internet. Again, modem status lights were all good and Orbi was not displaying the purple ring. Manually set my DNS and was able to surf the web right away. That is when I came to the forums and saw your post and someone else's.
In the other post, someone mentioned that setting your NTP server to something other than Netgear's may solve the issue. Weird, but okay. Maybe the differences in time was causing sync issues with the DNS servers? I set my NTP server to time.nist.gov even though the correct time was displayed in the Orbi web GUI. Crossing my fingers that this does the trick because we're all working from home and the kids have online classes.
If I wake up in the morning and find the Orbi is doing the same thing, I may pick up another router (not Netgear) and put the Orbi in AP mode.
Good luck to the both of us!
Bill01568
Mar 18, 2021Tutor
I'm having the exact same problem (as best as I can tell) with my RBR20. It started the same day that I upgraded from firmware version (I wish I knew!) to V2.6.2.104. The version number makes me think that it's closely related to the RBR50 firmware that is having problems.
- FURRYe38Mar 18, 2021Guru - Experienced User
Has a factory reset and setup from scratch been performed?
Also:
Bill01568 wrote:I'm having the exact same problem (as best as I can tell) with my RBR20. It started the same day that I upgraded from firmware version (I wish I knew!) to V2.6.2.104. The version number makes me think that it's closely related to the RBR50 firmware that is having problems.
- vajimMar 18, 2021Master
FURRYe38 wrote:Has a factory reset and setup from scratch been performed?
I believe they are reaching out to the moderators
- Bill01568Mar 18, 2021Tutor
Hi,
I did perform a factory reset (paperclip). I then restored my previously saved configuration because I've got custom DNS entries, I've got a range of static IP addresses for certain devices, and a bunch of other little changes that I would have forgotten about.
Is there a way I can extract all of my configuration (without having to perform a print-screen on every screen!) so that I can perform another factory reset, then configure from scratch using my preferred configuration? Having a text version of configs would be ideal so I could copy from the text, then paste values (MAC, IP, etc,) directly into the freshly reset configuration.
Bill
