kmikol42
Mar 16, 2021Tutor
Orb RB40 MAJOR DNS Issue
My $300 dollar Orbi investemnt appears to be a waste of money after 4 months use. All of a sudden the Router stops responding to DNS requests. I work in the network engineering field and have over ...
Bill01568
Mar 18, 2021Tutor
I'm having the exact same problem (as best as I can tell) with my RBR20. It started the same day that I upgraded from firmware version (I wish I knew!) to V2.6.2.104. The version number makes me think that it's closely related to the RBR50 firmware that is having problems.
Mar 18, 2021Guru - Experienced User
Has a factory reset and setup from scratch been performed?
Also:
Bill01568 wrote:I'm having the exact same problem (as best as I can tell) with my RBR20. It started the same day that I upgraded from firmware version (I wish I knew!) to V2.6.2.104. The version number makes me think that it's closely related to the RBR50 firmware that is having problems.
- vajimMar 18, 2021Master
FURRYe38 wrote:Has a factory reset and setup from scratch been performed?
I believe they are reaching out to the moderators
- Bill01568Mar 18, 2021Tutor
Hi,
I did perform a factory reset (paperclip). I then restored my previously saved configuration because I've got custom DNS entries, I've got a range of static IP addresses for certain devices, and a bunch of other little changes that I would have forgotten about.
Is there a way I can extract all of my configuration (without having to perform a print-screen on every screen!) so that I can perform another factory reset, then configure from scratch using my preferred configuration? Having a text version of configs would be ideal so I could copy from the text, then paste values (MAC, IP, etc,) directly into the freshly reset configuration.
Bill
Bill01568 wrote:Hi,
Bill
