kmikol42
Mar 17, 2021Tutor
Orb RB40 MAJOR DNS Issue
My $300 dollar Orbi investemnt appears to be a waste of money after 4 months use. All of a sudden the Router stops responding to DNS requests. I work in the network engineering field and have over ...
Blanca_O
Mar 22, 2021NETGEAR Employee Retired
Hi Orbi Community,
Engineering was able to discover the cause of this issue and they are working on a fix in regards to the disconnections.
The issue comes from Traffic meter while daylight saving is enabled. The quick workaround is to disable the traffic meter.
To disable traffic meter:
Access orbilogin.com > go to ADVANCED Tab > Advanced Setup > Traffic Meter and uncheck Traffic Meter
We appreciate all your cooperation and patience working with us. We will provide update once we have the fix firmware.
Blanca
Community Team
vajim
Mar 23, 2021Master
Thanks for the update
so it sounds like the problem is traffic meter as it plays with the newer firmware
I have DST activated but NOT the traffic meter on my older firmware with NO problems
