kmikol42
Mar 16, 2021Tutor
Orb RB40 MAJOR DNS Issue
My $300 dollar Orbi investemnt appears to be a waste of money after 4 months use. All of a sudden the Router stops responding to DNS requests. I work in the network engineering field and have over ...
Blanca_O
Mar 22, 2021NETGEAR Employee Retired
Hi Orbi Community,
Engineering was able to discover the cause of this issue and they are working on a fix in regards to the disconnections.
The issue comes from Traffic meter while daylight saving is enabled. The quick workaround is to disable the traffic meter.
To disable traffic meter:
Access orbilogin.com > go to ADVANCED Tab > Advanced Setup > Traffic Meter and uncheck Traffic Meter
We appreciate all your cooperation and patience working with us. We will provide update once we have the fix firmware.
Blanca
Community Team
