jcampagna42
Oct 17, 2020Follower
Orb RBR40 Router won't connect to Windows 10 desktop
I have 2 satellites connected to the router. The router is connected to an AT&T modem. Problems with slow internet started a few days ago. Found that some of the devices were assigned to a satellite ...
Oct 23, 2020Guru - Experienced User
Be sure the Windows 10 PC has updated network adapter drivers from the adapter mfr.
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1982974/highlight/true#M7849
