jcampagna42
Oct 17, 2020Follower
Orb RBR40 Router won't connect to Windows 10 desktop
I have 2 satellites connected to the router. The router is connected to an AT&T modem. Problems with slow internet started a few days ago. Found that some of the devices were assigned to a satellite ...
Mikey94025
Oct 23, 2020Hero
jcampagna42 wrote:1. All devices (phones, tablets, printers) are connected to Orbi, except for a Windows 10 desktop. Can't connect to the network is the error message. Not sure why this happened now. Have had the Orbi at least a year.
Right-click on the Windows wireless connection and select Forget, then setup the wireless connection again. It might be trying to reuse old info that has since changed so this is the best way to reset and connection again. If that doesn't work, run Windows Update and make sure your wireless network drivers are up-to-date.
