Markliley
Nov 20, 2019Aspirant
Orb showing two networks ORB1 and a satellite shows ORBI
My Orb180 router works with an outdoor satellite , showing ORB180, but when I plug in another RBR 50 it shows up as a separate network ORBl80. hope someone has the answer kindest regards Mar...
Nov 21, 2019Guru - Experienced User
I recommend that you change the SSID on the RBR180 router to something more unique and custom. SSIDs can be anything. Then begin to add the the RBS to the RBR again.
Markliley wrote:My Orb180 router works with an outdoor satellite , showing ORB180, but when I plug in another RBR 50 it shows up as a separate network ORBl80.
kindest regards
Mark
