dome045's avatar
dome045
Follower
Dec 31, 2020
ORB20 SIM PIN length
Few improvement proposals for the mobile setup app (Android) and possibly for the firmware of this ORBI LTE (ORB20) router: First I tried to install the router with the mobile app as it was recommende...
  • Blanca_O's avatar
    Jan 11, 2021
    Hi dome045
    This has been brought up already to engineers. They confirmed that the original spec is only 4 digits. They will work on updating the spec to support a max of 8 digit PIN. We will fix the issue and ETA is by end of Q1 2021.
    Blanca
    Community Team
