KitchSB
Jan 29, 2021Aspirant
orbe app update alert
my iOS Orbi app (version 2.8.0.15) keeps wanting firmware updates and is confusing the satellite FM for the router FW. Wants to make router same as satellite. See pic where .38 is the current satel...
- Jan 29, 2021
KitchSB wrote:CBR40 cable modem. Why does the app want to update FM when it is up do date? If you looked at the included screenshot, the app wants to update the modem version with the current satellite version. Attached again
The screen shot was why I concluded it was the CBR40. I have so little confidence in the "app" that I am not able to conclude anything from the picture. What I would do is log into the Orbi web interface and open the Advanced Tab, Administration, Firmware Update and see what it says.
CrimpOn
Jan 29, 2021Guru - Experienced User
KitchSB wrote:my iOS Orbi app (version 2.8.0.15) keeps wanting firmware updates and is confusing the satellite FM for the router FW. Wants to make router same as satellite. See pic where .38 is the current satellite FM and .16 the router. Should know the difference
The Netgear support web site shows the current firmware for the CBR40 (included cable modem) Orbi is indeed 2.5.0.14.
What model of satellite do you have?
KitchSB
- CrimpOnJan 29, 2021Guru - Experienced User
- FURRYe38Jan 29, 2021Guru - Experienced User
Please visit and post about this over in the Orbi with Cable modem forum:
https://community.netgear.com/t5/Orbi-with-Built-in-Cable-Modem/bd-p/en-home-orbi-cableThank you.
- KitchSBJan 29, 2021Aspirant
Crimpon, thanks. That app UPDATE indication bug has been there a long time and became irritating enough to investigate. I will ignore from now on.
I often us the web version and it generally works well.
I manually updated my 3 satellites with the newest version. So far so good. But has not found the best network map -- one is still 'poor' as is awkwardly connected. Wish there was a way to direct the network connections.
