malove's avatar
malove
Orbi - All ethernet ports shut down when one disconnects
I've got an Orbi BRK53 setup in my house. One of the satellites and three computers are connected through wired ethernet connections (two through a secondary switch). Everything else is wireless.
When I unplug one of the computers from the wired ethernet connections, it knocks out everything else that is wired offline (i.e., the satellite and other two computers). Everything connected to the now offline satellite also goes offline.
To fix the issue, I have to reset the Orbi system.
Does anyone know why this is happening? Or how to fix it?
    Sounds like a wiring issue. Coming from the Orbi RBR50 router, is the network cable connected directly to the wired RBS50 satellite, or is the switch in the middle? Try temporarily eliminating the switch to see if that is the problem.
    • malove's avatar
      malove
      The RBR50 is directly connected to the RBS50, one of the computers, and the switch. The switch then has two more computers connected to it (a room with one ethernet connection, that I am splitting to two computers).
      The computer that is being disconnected is one of the computers connected to the switch. Seems weird that unplugging one would create issues for everything else wired in.
      • Mstrbig's avatar
        Mstrbig
        Master
        So the network cable is coming from the RBR50 router directly to the switch? What brand and model is the switch? Have you run a temporary test cable to rule out the cable connection?
