Some_Dude
Oct 03, 2020Tutor
Orbi - Device Battery Life
I've seen some old messages with users having similar issues, but I haven't found one yet with a fix for my issue. I've got several portable devices that are seeing severe battery drain, but only...
Mikey94025
Oct 03, 2020Hero
I am not an Android phone user but your problem is very interesting, especially that connecting to the guest network reduces the battery drain effect. I found this on the internet which seems to say that other devices on the network are multicasting and causing your Android phone to wakeup: https://www.reddit.com/r/oneplus/comments/adz4us/wifi_battery_drain_caused_by_a_router/. Could something in your network be doing this, so connecting to the guest network solves it because that device isn't broadcasting there?
- Some_DudeOct 04, 2020Tutor
That sounds promising... I'll have to play with things and see if I can find a device that's frequently broadcasting to the network. Unforutunately this may be one of those issues that may require trial & error plus time, so I'll post back if I find out more.
