jaschultze
Apr 29, 2017Aspirant
ORBI - different IP ranges for wired devices
I'm have a strange issue. I have my Orbi set to assign IP addresses in the 192.168.1.2 - 254 range. Any wired deviced connected via ethernet to the base assign correctly. However, any wired device...
jaschultze
May 04, 2017Aspirant
Yes, I did try that but it was still assigning 10.0.x.x addresses for the wired connections. I did solve the problem, however by manually assigning the AV receiver and other device that were connected to the satellite to a 192.168.x.x address and all works as expected. Just strange that only the satellite assigns to a different ip range, even after a full factory reset. Even a device that was never connected to my network; wifi assigns correctly, wired to the base assigns corrrectly, wired to satellite 10.0.x.x.
