moonema
Mar 13, 2019Aspirant
Orbi - Ethernet connection
I am looking at deploying the Orbi AC3000 in my house. I think I will get the coverage needed (smaller system is slightly too small for my house). The question that I had was the following ...
moonema
So the Powerline adapter will interface correctly with the Orbi mesh network?
Mar 13, 2019Guru - Experienced User
If you have one plugged into the orbi router and one into the linux computer it will work. the orbi itself doesn't support powerline without an adapter.
- moonemaMar 13, 2019Aspirant
If you have one plugged into the orbi router and one into the linux computer it will work. the orbi itself doesn't support powerline without an adapter. --> that is what I was thinking thus the follow-up question. Seems like an expensive solution to get copper to my linux box but might be my only option.
- plemansMar 13, 2019Guru - Experienced UserYou could pick up a used or refurb powerline off ebay for fairly cheap. I've seen them go for around $20 fairly frequently.
Or you could continue to use your other router as an extender to utilize the ethernet port.- ekhalilMar 13, 2019Master
I'm using Netgear NCE3001 to provide me with an Ethernet interface to my Unix machine.
It basically a wireless to Ethernet adapter that should do the job for you.
