moonema
Mar 13, 2019Aspirant
Orbi - Ethernet connection
I am looking at deploying the Orbi AC3000 in my house. I think I will get the coverage needed (smaller system is slightly too small for my house). The question that I had was the following ...
Mar 13, 2019Guru - Experienced User
What is the Mfr and model# of the ISP modem the NG router is going to be connected too?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
WiFi on the satelite(s) can not be disabled even if using wired backhaul. When using wired backhaul the satellite becomes a AP in a remote location.
Currently my Comcast modem is sitting on top of a bookshelf on one side of my office because that is where the connection had to come into the room. I would be placing the main Orbi device next to that cable modem. I would be placing the satellite Orbi on the other side of my house to provide the necessary coverage. The issue I am having is that I currently using a router as an extender at my desk to provide the necessary Ethernet connection for a linux computer I am running. If I run the main Orbi and a Satellite in the same room to get the Ethernet capability I need at my desk will there be interference? I would still have the other Satellite in the other portion of my house to provide the full coverage needed.
I just don't want the two in the same room to walk over each other. Is there another product that Netgear sells that allows me to backhall the copper connection over wireless WITHOUT broadcasting the SSID out of the satallite. Can I just turn the WIFI off in the satallite to get the copper connection in the same room?
moonema
What is the Mfr and model# of the ISP modem the NG router is going to be connected too? CISCO DPC3008
What is the size of your home? Sq Ft? 2500
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials. --> it would easily be over 30 feet depended on where I place it.
- FURRYe38Mar 13, 2019Guru - Experienced User
Ok, checking your ISP modem for built in router and WiFi. It's not. Your good here and placement will be key. You should be good there too.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials. --> it would easily be over 30 feet depended on where I place it.WiFi on the satelite(s) can not be disabled even if using wired backhaul. When using wired backhaul the satellite becomes a AP in a remote location.
