Crasje
Aug 09, 2018Tutor
Orbi - Genie app - usage: stopped measuring?
Hi,
I have the idea that since the last update, I no longer see usage in the Genie app. Last month still shows some data however august shows nothing which is strange since I have updated apps ...
DarrenM
Aug 15, 2018Sr. NETGEAR Moderator
When you say genie app do you mean the Orbi setting in the web browser or the actual netgear genie app? If you are using the genie app you will want to switch over to the Orbi app.
DarrenM
- CrasjeAug 15, 2018Tutor
I have both the Orbi and the Genie app.
The Orbi app doesn't display usage and a lot of other functionality. So why would I want to switch?
Question remains, why doesn't the Genie app display usage anymore? I was very interested in those numbers.
