Seattlites
Feb 21, 2017Aspirant
Orbi - guest network?
No guest network? Did I miss something?
Yeah, you are missing something, the guest network is there, just login into the Web interface with your computer and enable it if it is not already enabled.
PS: If you have an older version of the firmware you will need to update it to the latest version before you see the Guest Network feature.
1 Reply
- ElyLuminary
