bigdad930
Jan 24, 2019Tutor
Orbi - how to change connected devices to 5G
Just bought a 3 pack Orbi ac2200 RBR20 today. I have two questions I hope the community can help:
1) After I connected my satellite located in basement, my Samsung TV was on 5G and it runs fast on ...
bigdad930
Jan 25, 2019Tutor
Thank you ... after I disable Daisy chain topology my basement Samsung TV is now in 5G with much faster speed for streaming.
I have another question. Right now if I look at all my connected devices they are all in Orbi router under "Connected Orbi" column. Why they are not connected to each satellite if they are close by to each node? Am I not fully utilizing each node or satellite function after I disable Daisy chain topology?
Thanks
ekhalil
Jan 25, 2019Master
bigdad930 wrote:
....... Am I not fully utilizing each node or satellite function after I disable Daisy chain topology?
This has nothing to do with Daisy Chain. Devices will connect first time to the node that becomes available first, usually the router becomes up first after a system reboot. "Smart" devices will later roam to a closer node if available, but there are "sticky devices" that just stick to the first node they connected to and never change that.
For those devices, just power recycle the device so it will connect to the closer node (router or satellite).
