kgsmethers
Apr 09, 2020Aspirant
Orbi - Internet Connection Issue with Metronet
I’m suddenly having issues with my Orbi RBR20 connecting to the internet and putting out a WiFi signal. I’ve done power cycles, hard resets, firmware downgrades, nothing appears to be working. Curren...
Apr 09, 2020Guru - Experienced User
So are both wired and wireless connections not working?
What exactly are you experiencing when your connected to the Orbi?
What devices do you have connected?
Does connecting a wired PC or laptop directly to the ONT work?
kgsmethers
It appears that just wireless connections are not working. If I plug laptop directly into the ONT it works fine. When connected to the Orbi via WiFi Nothing will loaf and iPhone is saying “no internet connection” in WiFi settings. Then that pop up will go away and it’ll appear to be connected but nothing will load.
On the Orbi mobile app it says that the status is online and will let me do a speed test, but that connection doesn’t push across to any other apps.
- FURRYe38Apr 09, 2020Guru - Experienced User
So wired thru the RBR works aswell?
Do you have RBS connected or just the RBR alone?
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router.
