Schildi
Jan 12, 2020Aspirant
Orbi - no light adjustments?
Hi All! I just set up my RBK 53S that I bought at Costco. The manual states that when clicking on one of the Satellites names under the devices menu, there are light adjustments for the LED lights....
Schildi
Thanks a lot!
Wow! I was on the phone with support for almost an hour (many hold periods), and at the end the support person suggested a complete reset and new firmware installation (same version, as I am up to date).
I am glad I did not go ahead with that.
Again, thanks for the help! Weird that they would not update the manual.
Jan 12, 2020Guru - Experienced User
A reset is mostly need if there are problems or if problems arise have a FW update.
Enjoy.
