huntertim
Apr 20, 2018Aspirant
Orbi - No wired or wireless
I have a Orbi RBR40 with 2 sattelites. It's been working fine since it was purchased around December of this year. Late last night all internet connections stopped, it's not the first time this h...
Apr 20, 2018Guru - Experienced User
What FW are you using on the Orbi system?
What is the Mfr and model# of the ISP modem your using with the Orbi system?
huntertim wrote:I have a Orbi RBR40 with 2 sattelites. It's been working fine since it was purchased around December of this year.
Late last night all internet connections stopped, it's not the first time this happened, so I was thinking it's an easy fix to reboot over the andriod app. Rebooted, and waited a few mins, the wireless came up for a min then disappeared.
Since then I haven't gotten anything to work over a wire or wireless connection. I get power, but never any other lights. Using the reset button (holding for 7+seconds while powered) doesn't seem to do anything.
