NortheastGuy's avatar
Dec 19, 2016
Orbi - Option to Automatically Update Firmware?
I'm trying to find out if Orbi has an option to automatically download and install firmware updates.  I'm really trying to get to a "setup and forget" situation with the Orbi;  So far I think performance has been stellar, but we're only now getting the tools to keep administration to a minimum.
Another option would be notifications from the app letting me know an update is available;  Right now when you connect to your network at home, the app tells you if there is an update, but its a "pull" notification rather than a "push".
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello NortheastGuy
    This is a great suggestion but right now you still have to login to the router to update it.
    DarrenM
    • NOS's avatar
      NOS
      Just bought my 3 pack from Costco for $499 today and set it up.   It's showing firmware is v1.2.0.6.  will I have to manually update the router and both satellites?   I'm a little leary to do it given the pain it was to get it connected to begin with.
      • dragoncat's avatar
        dragoncat
        You NEED to update to the latest firmware to access the new features (Guest Account capability for example) and for effective use of the two satellites.  Manual updating works well.  I have the same setup and all is working properly.
