NitrousX
Nov 11, 2018Aspirant
Orbi - Overide 2.4ghz/5ghz priorities and QOS
Hi Netgear, I am in the market to purchase a new mesh wifi hub.
As the title suggests, I am looking for a mesh wifi hub that allows me to overide which the automatic switching over wifi bands.
I ...
NitrousX
Nov 12, 2018Aspirant
Hi thank you for your reply. So I can use QOS from the router thats good. So what about choosing which wifi band per device as I explained earlier is this possible thanks
ekhalil
Nov 12, 2018Master
NitrousX wrote:
...... So what about choosing which wifi band per device as I explained earlier is this possible thanks
You can't do such configuration in Orbi, but in some devices (e.g Windows PCs, see snapshot below) you can select which band to use.
- NitrousXNov 12, 2018Aspirant
That's a shame that I cannot change the wifi band from the orbi. As I would be connecting my PC to a orbi via ethernet. Does Orbi use fastlane tech to change to 5ghz from 2.4ghz similar to what you can do with the EX7000 wifi extender?
- st_shawNov 12, 2018Master
If you connect your PC to Orbi via an Ethernet wire, your PC will not be using WiFi to connect to Orbi.
So why are you asking whether you can force your PC to use 5 GHz?
Main reason is that the range of my EX7000 has limited 5ghz range keeps dropping out. I have tweaked the bandwidth and placed the antennas from the router and extender as close as possible to each other. So ive done everything possible so i believe i need a new setup to make it work basically
