vanishevo
Apr 18, 2017Guide
Orbi - random reboots
Hi guys, Bought an Orbi around two weeks ago, everything was going fine until one week ago when the random reboots started. It most recently rebooted just 40 mins ago, as is reported within ...
- Jun 28, 2017
A quick update.. after swapping out the unit, everything now works fine!
Must have been a hardware issue.
The RMA process was very straight forward here in Australia, a replacement unit was sent out along with a return con note.. all too easy!
vanishevo
Apr 21, 2017Guide
Hi Darren,
It just rebooted itself again, was plugged directly into the wall.
Have you heard of anything like this before? Sounds like I'll need to return it.
Thanks
Thanks
- DarrenMApr 24, 2017Sr. NETGEAR Moderator
Hello Vanishevo
Yea you may need to exchange it or contact support.
http://www.netgear.com/support/contact.aspx?cid=wmt_netgear_organic
DarrenM
- PDaddyJun 28, 2017Guide
Happening to me as well. Very irritating problem.
