Netrunner1974
Sep 03, 2020Aspirant
Orbi - slow speed with XBOX One on ethernet
I have now had my Orbi RBR20 router with 2 satellite system for a few months and keep having issues. The latest one is the XBox One connection speed. It is currently wired with Cat5e through 2 switch...
Sep 03, 2020Guru - Experienced User
IF your laptop is getting to spec speeds on same switch line, then we can presume your xbox may be the issue. Game consoles have been problematic over the years when it comes to reliable speed test result. We don't know what test servers there using and if or how busy these severs are. I would always test with a wired PC and Ooklas installable speed test app behind the RBR and on the switch line. If your getting to specs speed thru the RBR and switches, then not much can be done on the Orbi system to make the xbox work better.
Test the xbox directly connected to the RBR.
What is the mfr and model of these switches?
Netrunner1974
Sep 04, 2020Aspirant
I tried early this morning (can't unhook the internet when everyone is awake...) and I obtained 200mbps download, and 30 mbps upload both when going through two switches as well as going straight to the router. So, the switches are not the issue. Next, I need to try my Bell Fibe router and compare with the Orbi router. This will be done next week (long weekend).
Also had an issue yesterday where my soan came over and said he did not have any internet. I verified, we both had full bars (Wi-Fi) on our phones, but no internet acccess. My wife was on another satellite on Wi-Fi and had internet access... Not a very reliable mesh sytem...
- FURRYe38Sep 04, 2020Guru - Experienced User
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? if there is a built in router here, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop- Netrunner1974Sep 04, 2020Aspirant
I have removed the service provide's (Bell) modem/router combo, so no double NAT issue. I am using a TP_Link MC220L Gigabit Media Converter to convert the optical signal to electrical and then using the Orbi router.
Be sure IPv6, Armor and Circle are not enabled.
Seems like of a wired laptop is getting good speeds thru the RBR and the xbox isn't, xbox isn't testing correctly.
