ShreeMoorthy
Jan 03, 2021Star
Orbi - Slow upload speeds
Here's the issue: My ISP plan is 200 Mbps Up and Down. Connected to the router with cable, upload and download speeds are 220 Up and 220 Down. The mobile app's speedtest shows 220 Up and 220 Down...
Jan 04, 2021Guru - Experienced User
What devices are you using to check the speed?
Be sure you are connected to the RBS. Turn OFF the devices wifi radio for 5 seconds then back on while near the RBS?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1982974/highlight/true#M7849
ShreeMoorthy wrote:Here's the issue:
- My ISP plan is 200 Mbps Up and Down.
- Connected to the router with cable, upload and download speeds are 220 Up and 220 Down.
- The mobile app's speedtest shows 220 Up and 220 Down.
- On Wifi:
- Near the satellite or the router, I get Download speeds of 220 Mbps, but 70-90 Mbps Upload.
- This never happened before, and has baffled me.
Any ideas appreciated.
Thanks and Regards.
