MMoret
Aug 06, 2019Follower
Orbi - sometimes no data after switching to router mode
Hi all, I have a RBR40 with two RBW30 wall sattelites. Untill recent I used them in AP mode with no problems. Due to a change in provider/modem I now use it as Router with my internet connection on ...
Aug 06, 2019Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
