LMFAR
Mar 14, 2019Aspirant
ORBI - SPLENDID GEAR BUT WITH A MAJOR DISSAPOINTMENT
I BOUGHT A ORBI SYSTEM 1 RBR50 PLUS 2 SATELITES.
I WAS A PREVIOUS USER OF 3 A APPLE AIRPORT WIRED CONNECTED AND I DID THE SAME WITH ORBI.
REASON TO CHANGE : BECAUS EI DO NOT LIKE TO HAVE DISC...
michaelkenward
Mar 14, 2019Guru - Experienced User
Do you have some sort of problem that you want help with fixing? I can't see one in your message. Is it all down to the USB drives?
If you do want help try posting in the appropriate bit of this community.
NETGEAR : YOUR BEHAVIOUR HERE IS SOEMWHAT NOTTY.
Not sure what you are on about there (notty?), but you should know that this community is essentially a user-to-user venue with some input from a small band of Netgear techies.
Most of the answers come from fellow users who have no connection with Netgear. They just have a lot of collective experience and are familiar with the sort of problems that turn up here.
If you want "official" support then you should go through the right channels.
Contact Us | Support | NETGEAR
By the way, there is no need to SHOUT. It makes messages hard to read.
- LMFARMar 17, 2019Aspirant
The help I need is how to connect an external USB hard drive to the USB port that comes in ORBI Routers and Satelites.
My apologies beforehand if that was not noticed in my previous post.
Kind regards
