bigitybadb
Jul 07, 2020Aspirant
Orbi - Stopped Working and No Ring Lights!
Hi all, I have the Orbi Router RBR50 with a single satellite that's connected to the router via a CAT6 cable. The product worked great for 12.5 months, then the satellite stopped working. The gre...
Jul 08, 2020Guru - Experienced User
OK, seems like the RBS is just bad now. Needs replaced. :smileyfrustrated:
SLK-Purdue
Jul 09, 2020Luminary
Do you have any top led lights at all? If so, I have had pretty good luck de-bricking these. DM me and we can talk about it.
Scott
