zowa
Aug 29, 2018Aspirant
Orbi - Torrent and DNS problem
Hello,
I have the following problem:
Orbi (2 units) router mode. When I download something using a torrent client (uTorrent), the DNS name resolution stops.
The network connectivit...
zowa
Sep 06, 2018Aspirant
It is clearly a Netgear problem. They have a bugged product, and they don't even care to solve it, even with many people reporting it.
mith_it
Sep 06, 2018Luminary
zowa,
Go to the Web UI of the router, in the basic settings tab click on "Internet" around the middle of the page you will see the menu to manually configure the DNS. Try that one to see if your router is not picking up the dns from your provider.
- zowaSep 06, 2018Aspirant
It does not matter what DNS server is being used by Orbi. I have tried many...
The problem is that Orbi stops responding DNS queries to connected devices. And there is no option to change the DNS server distributed do clientes by Orbi's DHCP service.
- FURRYe38Sep 06, 2018Guru - Experienced User
You may have just a bad unit. No body else has posted about what your seeing. You might contact NG support and ask for additional help and information and ask for an RMA.
- elocsinJan 05, 2019Aspirant
That's incorrect. I've been dealing with this issue since I setup the Orbi during the summer. Everything is fine up until I start a torrent client on the machine and after a few minutes of downloading, DNS resolution and ping start to fail. As soon as I kill the client, DNS resolution and ping start working again. My old Linksys router never had this problem.
- FURRYe38Jan 05, 2019Guru - Experienced User
Possible that your torrent is maxing out bandwidth connection thru the Orbi. Try setting your Torrents downloads to something minimal to start and see if the download problem still happens?
Can you download something usuing a browser from a web site and does the problem happen during a web site download?
What FW is currently loaded?
