PikerFlinn
May 25, 2019Initiate
ORBI - USB Hard Drive support
It is singly the most disapointing issue with the router - NO USB Hard Drive Support. Sadly this means I will not be purchasing any more of these products unless and until this is rectified. Expensiv...
Bambooken
Nov 02, 2019Aspirant
What do I need to do in order to simply plug a 4TB Harddrive into my RBR50 as a shared drive between the various household computers?
It's looking like the USB port is not going to do it.
What if I connect the drive to the RBR50 via a USB to Ethernet adapter?
Apologies if this has been covered but the USB issue is hard to cut through to get a direct answer to my question.
TIA!
RBR50 + 2 satellites
Firmware Version V2.3.5.30
Mostly Mac ecosystem
