Marktwain
Dec 04, 2016Follower
Orbi - Wave 2
Is the Orbi/Satellite combinatation package a wave 2 router?
Irishbrowncoat
Dec 14, 2016Star
Question, if the backhaul is 5 GB 1733 should the satellite be showing in the Netgear Genie as having a connection to the main router of only 100 MBPS? I assume since it is excluse to 5GB 1733 then the genie should be showing a connection speed higher than 100 MBPS. For instance my iPhone 7 shows a connection of 800+ to the main router. Why only 100 for the Satellite?
DarrenM
Dec 14, 2016Sr. NETGEAR Moderator
Hello Irishbrowncoat
It could be with band steering that the satellite is putting the phone on the 2.4 ghz or its staying connected to the main router on the 2.4ghz when connected far away.
DarrenM
