ChristineT
Jul 19, 2017NETGEAR Employee Retired
Orbi - Wireless Network not available or LED flashing white on Router or Satellite
The NETGEAR team has noticed an issue with upgrading some Orbi Tri-Band WiFi System Model RBK40, RBK43 and RBK30 units in the field to OrbiOS 1.12.0.18. If your Orbi are affected, the symptoms are: ...
shorepath
Jul 23, 2017Aspirant
Satallite RBS40 will not connect to main router RBR40. Connected on initial setup changed to flashing white light for over 72 hours. Tried factory reset and suggested troubleshooting. Still not connecting. Called Netgear over an hour on hold still no one answered with priority assistance. Any suggestions would be helpful. I am NOT a tech savy person. Thanks in advance.
