ChristineT
Jul 19, 2017NETGEAR Employee Retired
Orbi - Wireless Network not available or LED flashing white on Router or Satellite
The NETGEAR team has noticed an issue with upgrading some Orbi Tri-Band WiFi System Model RBK40, RBK43 and RBK30 units in the field to OrbiOS 1.12.0.18. If your Orbi are affected, the symptoms are: ...
sjob
Aug 03, 2017Guide
I have the same problems. Internet outages, satellite blinking white.
Please advice what to do.
DarrenM
Aug 04, 2017Sr. NETGEAR Moderator
Hello Sjob
Try to downgrade to the 1.11.0.20 firmware and if that still does not work you will want to contact support.
http://www.netgear.com/support/product/RBK40.aspx#download
DarrenM
- suprafunAug 07, 2017Aspirant
I too have been having internet connection issues recently. I have been having to reboot the Orbi multiple times a day. when will this get fixed? I used to love the Orbi and i just want it working again!
