ChristineT
Jul 19, 2017NETGEAR Employee Retired
Orbi - Wireless Network not available or LED flashing white on Router or Satellite
The NETGEAR team has noticed an issue with upgrading some Orbi Tri-Band WiFi System Model RBK40, RBK43 and RBK30 units in the field to OrbiOS 1.12.0.18. If your Orbi are affected, the symptoms are: ...
DarrenM
Aug 04, 2017Sr. NETGEAR Moderator
Hello Sjob
Try to downgrade to the 1.11.0.20 firmware and if that still does not work you will want to contact support.
http://www.netgear.com/support/product/RBK40.aspx#download
DarrenM
suprafun
Aug 08, 2017Aspirant
I too have been having internet connection issues recently. I have been having to reboot the Orbi multiple times a day. when will this get fixed? I used to love the Orbi and i just want it working again!
- DarrenMAug 08, 2017Sr. NETGEAR Moderator
Hello suprafun
What firmware version are you on?
DarrenM
- suprafunAug 08, 2017AspirantFirmware: 1.12.0.18
Hello suprafun
We have a updated version of that firmware try to load that. If you have the RBK40
DarrenM
