smacdoncu
Dec 29, 2017Aspirant
Orbi - Xbox One issue - Double NAT - Strict
Hey guys. I've had the Orbi for a few weeks, and I'm just now getting a strict NAT on my Xbox One. A double NAT is being detected. My house is wired for fiber, so I am only using the Orbi for a route...
smacdoncu
I’m in router mode, but if I switch to AP mode I lose wireless right? Sorry in advance for me not knowing this.
guzzijason
Dec 29, 2017Apprentice
No, you keep wireless in AP mode. The difference is that in AP mode, clients of the Orbi get their IP addresses directly from your main router that the Orbi is connected to. You can think of AP mode as an extension of your other security gatway, rather than a separate router, which is is now. You essentially have one router connected to another today.
- smacdoncuDec 30, 2017Aspirant
Ok, so I've tried pretty much everything. Switched over to AP (didn't work), took the other router away (didn't work), put the different ports in port forwarding (didn't work). Nothing is working or changing it over from Double NAT. Pretty frustrating, since I didn't change any configurations, and it went from working last week, to not working now. Any other advice would be appreciated! Thanks!
- DarrenMJan 03, 2018Sr. NETGEAR Moderator
If you have orbi In AP mode and you are still getting a Double NAT then its port forwarding issue in your main router.
DarrenM
