smcg
Mar 06, 2021Aspirant
Orbi : 2 satellites running at 300mb hub starts there but gradually slows to 40mb
Hello, Would be hugely grateful if someone could help me with this. The title says it all: I've got fast access from Virgin and their hub is in modem mode and connected to our RBR50 by cable. ...
smcg
Mar 08, 2021Aspirant
Hi,
They are RBR50|Orbi AC3000 Tri-band WiFi Router, and 2 x RBS40|Orbi AC2200 Tri-band WiFi Add-on Satellite.
Firmware on all three is v 2.7.2.104
Speed this morning has slowed to 22mb.
Many thanks for taking the time too ask.
Aye,
S
Mar 09, 2021Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1982974/highlight/true#M7849
Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
smcg wrote:Hi,
Aye,
S
