GRIVAL
Jun 04, 2019Aspirant
ORBI + 4G LTE EXTENDER SAMSUNG FROM VERIZON = unable to connect to Verizon server
I have a Samsung 4G Extender that I purchased from Verizon that I need for working from my home office. I have followed the instructions below but it is stuck at step 8 which is to connect to Verizo...
- Jun 04, 2019
PROBLEM SOLVED
In the hope that this might help someone else, I just called Verizon and turns out they didn't have the extender provisioned - so they did it over the phone and it all started to work.
I also decided to remove the extender from DMZ - for security reasons - and it's still working fine.
Did a few test calls and watched the status stay green for 20minutes now.
Thanks for the support.
Jun 04, 2019Guru - Experienced User
Try this, remove the Port Foward configuration for the extender from the RBR. Input the IP address the extender is getting from the RBR into the RBRs DMZ. I do this for my ATTmicrocell. Works great.
GRIVAL
I removed the port forwarding - seems it did not impact the working DNS port.
And I added the extender IP to DMZ.
Still same status.
Router Firmware Version V2.3.1.60 on the Orbi
Connected to a ISP Modem from SPECTRUM Model= E31N2V1 Brand= Hotron Technologies, Inc. Type= DOCSIS 3.1 eMTA
just in case extender info= Verizon SAMSUNG 4G LTE Extender Model#SLS-BU103
- GRIVALJun 04, 2019Aspirant
Here is the extender Status after these changes:
Server Connectivity StatusServer Status Date & Time IP Address & PortDNS Reachable 06-04-2019 12:58:16 GMT IP 192.168.1.1 Port 53IPSec Not Reachable 06-04-2019 12:58:19 GMT IP Port 500Location Assistance Not Reachable 06-04-2019 18:30:46 GMT IP 209.210.15.73 Port 52428- GRIVALJun 04, 2019Aspirant
PROBLEM SOLVED
- FURRYe38Jun 04, 2019Guru - Experienced User
Ah glad it was a service issue over a configuration issue.
Please mark your thread as solved so others will know.
Enjoy. :smileywink:
GRIVAL wrote:PROBLEM SOLVED
