GRIVAL
Jun 04, 2019Aspirant
ORBI + 4G LTE EXTENDER SAMSUNG FROM VERIZON = unable to connect to Verizon server
I have a Samsung 4G Extender that I purchased from Verizon that I need for working from my home office. I have followed the instructions below but it is stuck at step 8 which is to connect to Verizo...
- Jun 04, 2019
PROBLEM SOLVED
In the hope that this might help someone else, I just called Verizon and turns out they didn't have the extender provisioned - so they did it over the phone and it all started to work.
I also decided to remove the extender from DMZ - for security reasons - and it's still working fine.
Did a few test calls and watched the status stay green for 20minutes now.
Thanks for the support.
GRIVAL
Here is the extender Status after these changes:
Server Connectivity Status
Server Status Date & Time IP Address & Port
DNS Reachable 06-04-2019 12:58:16 GMT IP 192.168.1.1 Port 53
IPSec Not Reachable 06-04-2019 12:58:19 GMT IP Port 500
Location Assistance Not Reachable 06-04-2019 18:30:46 GMT IP 209.210.15.73 Port 52428
GRIVAL
PROBLEM SOLVED
