GRIVAL
Jun 04, 2019Aspirant
ORBI + 4G LTE EXTENDER SAMSUNG FROM VERIZON = unable to connect to Verizon server
I have a Samsung 4G Extender that I purchased from Verizon that I need for working from my home office. I have followed the instructions below but it is stuck at step 8 which is to connect to Verizo...
- Jun 04, 2019
PROBLEM SOLVED
In the hope that this might help someone else, I just called Verizon and turns out they didn't have the extender provisioned - so they did it over the phone and it all started to work.
I also decided to remove the extender from DMZ - for security reasons - and it's still working fine.
Did a few test calls and watched the status stay green for 20minutes now.
Thanks for the support.
schumaku
Jun 04, 2019Guru - Experienced User
GRIVAL wrote:
>> Unable to enable VPN in the ORbi advanced setting when checking "Enable VPN" checkbox to enable VPN service and then click apply it returns this error message : " 400 Bad RequestThis server does not support the operation requested by your client." - since it is stuck on IPSec then this might be the source of the problem??
Yes, that's most likely the problem. The community, and much more Netgear does have to know which firmware is currently on your RBR50.
