adamsky
Dec 21, 2018Aspirant
Orbi & Alexa - guest WiFi network issues
Alexa is enabling the guest WiFi network with my Orbi RBK53 set but:
- the guest wifi network is unprotected (accessible without password). I can enable the same guest wifi (without modifying i...
Dec 24, 2018Guru - Experienced User
I recommend you contact NG support and ask for help and information regarding this.
