-jonk-
Dec 20, 2019Follower
Orbi / Anova connection
I had issues with connection of my anova bluetooth / wifi connection. Tried multiple solutions on this site and google. This one worked perfectly for me:
Be sure that your phone is connected to a 2.4 network (orbie has both - which could have been the route of the problem). The anova app will use whatever wifi your phone is connected to.
Please follow the basic troubleshooting steps below.
-Please uninstall the Anova app.
-Reset the Precision Cooker by holding the WiFi / Bluetooth light indicator (located on the touch panel) down for 3-5 seconds. You will hear a beep. Do it twice. Unplug cooker, wait the a minute then plug the cooker back in to the power outlet.
-Make sure the Precision Cooker isn't more than 5 ft away from the router for the initial setup and all your WiFi extenders / repeaters are disabled.
-Reinstall the app, reboot your phone, enable your device's Bluetooth, launch the app and go through the setup process again."
1 Reply
Good information. Thanks for letting us know. Be sure to mark your thread and solved so others will know.
Enjoy. :smileywink:
