swayneberry
Jan 20, 2021Follower
Orbi & ATT Uverse arris modem router
Hello, all. I have done lots of digging on the ATT forums and Netgear and can't seemto find a fix for my exact problem and hope someone out there can help. I have a Orbi RBR20, satellite, and arris...
Jan 20, 2021Guru - Experienced User
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
ATT Dumb Switch Method:
https://community.netgear.com/t5/Orbi-AX/Orbi-AX-6000-and-AT-amp-T-fiber-gateway-issue/m-p/1890125/highlight/true#M2756
Please visit and post about this over in the Orbi AC forum:
https://community.netgear.com/t5/Orbi/bd-p/Orbi
Thank you.
swayneberry wrote:Hello, all. I have done lots of digging on the ATT forums and Netgear and can't seemto find a fix for my exact problem and hope someone out there can help. I have a Orbi RBR20, satellite, and arris bgw210-700. I just switched to ATT Uverse and am not able to access my Orbi router via its IP address. It was assigned a different address by the arris router that won't let me view/access the router like I did before. ATT had me change some settings on Arris, but I did nothing ( like AP mode) on the Orbi. Settings that were changed on the Arris were IP passthru and disabled wifi. So all I want to do is use the Arris as a internet gateway to ATT's fiber and have my Orbi manage my Wifi. With the Arris wifi disabled, that is happening right now, but if I have issues with the Orbi, I can't get into any of its settings, etc. Please, what additional changes do I need to do to each device to accomplish this? Thanks in advance!!
BTW, I do not have a the ATT TV and DVR. Seems many posting I see have this as an additional complication.
