mlinman
Oct 03, 2019Follower
ORBI- Can it be used with non-Netgear routers?
Hi, I recently bought an Orbi Router/Satelitte system from a friend. I'm just wondering if it should work with any modem or if it has to be Netgear? My modem is Arris. Thanks in advance for any h...
Retired_Member
Oct 03, 2019
mlinman wrote:Hi, I recently bought an Orbi Router/Satelitte system from a friend. I'm just wondering if it should work with any modem or if it has to be Netgear? My modem is Arris.
Thanks in advance for any help! :)
You may want to change the title of your post to: ORBI- Can it be used with non-Netgear modems?
michaelkenward
Oct 05, 2019Guru - Experienced User
Some people also like to use Orbi systems with non-Netgear routers.
To do that, it helps to put the Orbi router into wireless access point modem
