snaptopixel
Mar 21, 2018Tutor
Orbi & Circle?
Are the current firmware issues related to Circle, or other things? Is there any chance we could get a firmware update with only the Circle features and nothing else (no wired backhaul ,etc)? I'm...
snaptopixel
Mar 21, 2018Tutor
Where did you get the firmware? Iâve updated to the latest available 2.0 something. I bet you probably got the firmware before they pulled it down đ§
Starbucky
Mar 21, 2018Apprentice
You have to manually download under "View Previous Versions" in the downloads section for your particular product. Download the firmware files both the router and satellite and apply them manually using the web interface. It is recommended to apply the firmware to the satellite first then the router.
