PMD99365
Jan 12, 2018Aspirant
Orbi + existing wired network
Hi. I have a question regarding the Orbi RBK50 and existing wired devices, hope someone can help. I can't find information regarding this. My existing fibre router is hardwired to a number of Eth...
PMD99365
Can I just configure a couple of Orbi devices in AP mode and chain them from my existing router, then connect the existing devices (NAS, PC, switches etc) to the Orbi devices using ethernet? Would that work?
- st_shawJan 12, 2018Master
Yes. If you run Orbi in AP mode you can plug the RBR50 into your wired LAN anywhere behind your router.
However, you shouldn't move a device from your existing wired infrastructure to an Orbi LAN port unless absolutely necessary. Doing so will reduce the throughput for those devices, as the data will flow across the Orbi backhaul, rather than your wired network.
- wase4711Jan 12, 2018Luminary
If you take your existing wired router out of the picture completely, and use the Orbi system as a total wired/wireless solution, then you should continue to get the same fast wired through put that you were getting before, plus the enhanced benefits of the Orbi wireless network as well, correct? I've only been using the Orbi as an AP/Upgraded wireless network up to this point, for fear that it might not work as well for my wired network as my existing wired router works..
- passyMay 14, 2018Aspirant
I have a similar setup where my isp router feeds a master switch from which ethernet cables go to several sockets around the house.
If I plug an orbi router (in access point / ap mode) in one of the ethernet socket (to get internet from the ISP router), can I plug the satellite in another socket (also linked to the ISP router via the master switch)? And if yes should I use the WAN or the LAN port on the orbi router?
There would be only one cable to / from the router and therefore it would be different from the recommmend configuration whether the orbi router (in AP mode) gets internet on its WAN port and gets connected to the satellite via a different ethernet cable / network plugged into its LAN port.
