RegDawg
Jun 21, 2018Apprentice
Orbi + Gigabit
I have gigabit speed through Xfinity and with my Orbi router hard-wired to the modem, doing speedtests using the orbi app, I'm only roughly getting 400-500mpbs. When I hard-wire a Microsoft Surface 4...
Jun 21, 2018Guru - Experienced User
You need to ERASE the router back to factory and then set up from scratch. This time do not use the built in speed test, traffic meter or access controls on a 1Gb ISP service as these will disable the HW acceslleration needed for 1Gb ISP services. Then speed test with a wired LAN connected PC.
RegDawg wrote:
I have gigabit speed through Xfinity and with my Orbi router hard-wired to the modem, doing speedtests using the orbi app, I'm only roughly getting 400-500mpbs. When I hard-wire a Microsoft Surface 4 to the Orbi router, doing speedtests using speedtest.net or fast.com, I'm only roughly getting 300mbps. Is there something wrong with my set-up?
bd81
Jun 21, 2018Tutor
I'm not sure I agree with your post. He is most likely using an Ethernet adapter or maybe even testing wirelessly and that would explain the lower speed. The built in speed test is not accurate, my guess it simply does not last long enough to test 1 Gbit service. I have verified this with my service many times. I can hardwire my i7 laptop with a built in 1 Gbit Ethernet port and I will test 940 Mbit with my SIP, around 880 Mbit on speedtest.net and 940 Mbit on dslreports.com speedtest. The built in speed test will max out at about 450 Mbit or so.
- DavidUnboxedJun 21, 2018Star
Perhaps. However, there exists on the community posts here some screen captures showing much higher built-in speed test results. It could also be the 'hardware acceleration issue mentioned in the thread I linked. Only testing will tell.
- RegDawgJun 21, 2018Apprentice
Yes I'm using a gigabit adapter but when plugged in directly to the modem, I'm getting 800+mpbs on speedtest.net. As suggested by some to reset my modem and set it up from scratch disabling the speedtest, access control, and traffic meter....I set it up from scratch but I did not come across any options to "disable" the speedtest feature, access control, and the traffic app. I went through the set-up using the Orbi app. Did I miss something somewhere? After my set-up I hard-wired my surface pro 4 to the Orbi router and am getting about 450mbps so its still half of what I should be getting.
- bd81Jun 21, 2018Tutor
You will find those features if you go to www.orbilogin.net in your browser and use admin for user name and whatever password you picked. It should be all under Advanced tab. I never use the app for network setup, it is dumbed down and missing a lot of options.
Thanks for that. Well I logged in and access control is disabled, traffic meter is disabled, but could not find how to disable the speedtest option. I hard-wired my surface pro 4 to the orbi router and roughly getting 550-600mbps. Just to test, I did a speedtest on my desktop which is hard-wired to the satellite and I'm roughly getting 600+mpbs.
So just to summarize:
- Surface Pro 4 hardwired to modem - 800+mbps
- Surface Pro 4 hardwired to Orbi Router - roughly 550-600mbps
- Desktop hardwired to Orbi Satellite - roughly 600+mbps
I'm not sure what to think at this point. Any other things I can check?
