Ankuragg
May 13, 2018Tutor
Orbi- peculiar problem
Have been using orbi router + 1 satellite for over 4 months now. Works well in all rooms except one room that is further away. Although the wifi bars show 3 to 2 in that room, the internet does not se...
- May 17, 2018I took away the DIR-615 completely and directly connected orbi router to RJ45 from wall with orbi in router mode last evening. Did PPPoE internet connection with isp provided username password and internet got connected. Thanks for the suggestion.
I am still not sure if my original problem of farthest room not getting internet while wifi signal shows medium to good is completely solved but seemed to be holding longer in this room now. Will monitor for few days
May 16, 2018Guru - Experienced User
Some ISPs do that. The OP will have to ask the ISP.
Retired_Member
May 16, 2018
which ones?
- AnkuraggMay 17, 2018TutorI took away the DIR-615 completely and directly connected orbi router to RJ45 from wall with orbi in router mode last evening. Did PPPoE internet connection with isp provided username password and internet got connected. Thanks for the suggestion.
I am still not sure if my original problem of farthest room not getting internet while wifi signal shows medium to good is completely solved but seemed to be holding longer in this room now. Will monitor for few days- Retired_MemberMay 17, 2018
I am still not sure if my original problem of farthest room not getting internet while wifi signal shows medium to good is completely solved but seemed to be holding longer in this room now. Will monitor for few daysNice. What did your ISP say about a modem requirement? If your connection is straight from the wall outlet using a RJ45 (ethernet) to the Orbi, it sounds like your ISP is handling the modem function on their end. My experience is with the ISP coming into the house via a coaxal cable which must be converted via a modem. Who is your ISP?
- AnkuraggMay 17, 2018TutorI did not call them just tried out direct connect based on suggestions here. Does look like they have modem etc upstream before my apartment. I am based in Bangalore and it is a local ISP here.
- FURRYe38May 17, 2018Guru - Experienced User
Seems like you were in a double nat condition. Glad you got it working better.
Let us know if you see any other problems. You should be good now.
